archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Climatic comfort in big volumes buildings :Air treatment unit EOLIS are designed for use in commercial (supermarket) or industrial (workshop, hall) buildings, into which the air flow must be permanent but temperature increase must be regulated from 0 up to 45°C. Additionally, EOLIS are able of cooling.This product range cover applications from 10 000 up to 90 000 m3/h, with power from 50 up to 800 KW and pressure available can reach 600 Pa.Units are 50 mm thickness double skin type, with painted steel sheet and aluminium structure. A 100 mm high integral frame guarantee rigidity and airtightness. Any filtrations are available up to F9. For cooling, units are delivered with water coils.Double flow system are possible with or without plate exchanger.Remote control and regulations devices are settled onto the units in factory and AIRCALO do the start-up of unit on site.
Weiterlesen...
Weiterlesen...
