archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Danube's wide range of washer extractors has been designed to reduce water, utilities and detergent consumption. Most of our machines require 11 litres of water per washed kg (mild temperature without pre-wash). Danube washers are built to have high quality wash and very efficient extraction (G Force up to 440 on some Danube lines). With less water and efficient extraction you will save money on water and utilities. There is less water to heat, with high removal, so drying the linen is faster and uses less energy. All our machines are built to last and are designed with large door opening, quite operation and a lot of ergonomic features. All your operation costs will be kept to a minimum, therefore your return on investment will be faster....
Weiterlesen...
Weiterlesen...
