archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The FRANCESCA is beautifully hand made, hole in the wall bio-ethanol fireplace (gel fire). This high quality gel fire design is hand made in the UK. Stylish and practical providing a real source of heat and a feature fireplace for properties without a chimney or gas supply. The 400mm wide ribbon fire gel burner produces 2.7kW of heat for the room. The burner has been designed for use with either gel fuel or bio-ethanol. "BUILT IN, FLUELESS, SMOKELESS, ECO AND ENVIRONMENTALLY FRIENDLY" This gel fire design is manufactured to a very high standard, overall fascia size 990mm (w) x 590mm (h). The Francesca contemporary gel fire fireplace design requires no chimney and is safe and clean burning with our eco-friendly gel burner which is 100% energy efficient. See below for full technical specification and options bespoke designs are available upon request. ICONIC STYLING! Our Gel Fires have been in properties around the World including UK, Ireland, Germany, Dubai, Kuwait, Australia and are specified by the World's leading Interior Designers and Architects. To view a HD VIDEO of this fire visit our website. TECHNICAL: Burner : Strip Burner [400mm wide] with large flame. Tray Volume : 0.5ltr Running Time : 2 hours/ltr [varies depending on fuel type and brand] Heat Output : Approximately 2.7kW. Flue : No Chimney Required (Flueless) BUYING OPTIONS: Enclosure : Satin Black Steel (Stainless Steel upon request) Trim : Stainless Steel (Satin Black Steel upon request) Ceramics : 24pc Pebble Set or 5pc Log Set (extra cost). DIMENSIONS: Outer Trim Size - 990mm (w) x 590mm (h) x 2mm (d) Enclouse Size = 690mm (w) x 390mm (h) x 250mm (d) Bespoke designs are available upon request. Double sided or "Tunnel" version available upon request. Our new 2010 Bio-Ethanol fireplace catalogue is now available.
Weiterlesen...
Weiterlesen...
