Flexi Screen
archiexpo
12. August 2008
Flexi Screen is the ideal portable solution for vocal recording in untreated rooms, or venues which lack sufficient acoustic control. It performs on untreated and scattered room reflections, effectively isolating the sound source. Flexi Screen is made from high quality materials. Its polyurethane structure is designed to give maximum absorption efficiency. The addition of wood to the exterior surface helps create a barrier and gives an attractive visual effect. The singer's energy is absorbed on the inside of the unit, producing a dryer, less ambient sound. At the same time, scattered room reflections are treated on the outside. Flexi Screen can be used with a range of microphones and can be adjusted either horizontally or vertically. Product Technical Information Material – Acoustic Foam and Wood Colour – Charcoal Grey and Light Brown (wood) Adjustment – 2 Positions
Weiterlesen...
