Flexi Multi DC Invertor - Mutli Split Heat Pump Systems
archiexpo
12. August 2008
The flexible solution The new SANYO Flexi Multi range of heat pump multi split systems are the ideal, flexible solution for providing quiet and efficient air conditioning to 2, 3 or 4 areas (new Flexi Multi SAP-CMRV3636EH even up to 5 areas!) from a single outdoor unit. Features and benefits - 5 system capacities 4.0kW to 8.0kW - 6 indoor model styles - 2, 3 or 4 way multi split - DC inverter technology for precise temperature control and low start current - Provides heating or cooling as required R410A refrigerant The Flexi Multi systems utilise the non-ozone-depleting R410A refrigerant. This means increased system performance, increased energy efficiency and improved heat transfer, which results in smaller pipe sizes and more compact indoor units. All Flexi Multi DC inverter models are rated as EEL Category A, which confirms that they are amongst the most energy efficient systems available. Power consumption during operation is substantially less than that of lower rated units and consequently both the day to day running costs and full life cycle costs are significantly reduced. Simple, one touch control - Full function remote controller - Built-in temperature sensor - Temperature setting - Operational mode selection - Fan speed control - 24 hour ON/OFF timer - 1 hour timer Design guaranteed for an extremely efficient and flexible operation. - 4 models with capacity from 4.0 to 8.0 kW - DC inverter technology for precise temperature control and a low start-up current - Twin rotary compressor: the dual rotors guarantee perfect balancing ensuring functional reliability and efficiency. - This also contributes to increase comfort and accelerate cooling and heating as well as ensuring an extremely quiet and efficient operation. - Energy class A/A for the whole range, both in cooling and heating modes - Operating range decreased to -15°C in heating mode and -5°C in cooling mode - The volume of the external unit has been decreased by 9%, solving the problem of limited pace and does not encumber the exterior - Non-stop heating by means of SANYO's exclusive hot gas by-pass system - Renewable and washable apatite ceramic filter - Photo-catalytic LED sterilization function ensures excellent performance in eliminating odours, germs and bacteria (only wall-mounted units) - Night Set back/Economy modes to guarantee quiet and energy-efficient cooling and heating - Programmable start-up and shut-off via 24 hour clock
Weiterlesen...
