archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Flex-c-ment Overlay System offers a perfect solution to the present need to purchase a high quality building material for less. Our natural Stone patterned stamps create remarkably realistic natural Stone look on solid surfaces. Try this miracle coating product and Attend our Decorative Concrete Overlay training on June 17-19,2009 and become a Flex-c-ment Installer or Distributor in your Region. We manufacture a cementitious dry mix designed specifically for deep wall textures, creates the appearance of various stone and brick patterns. Some examples of Flexcement versatility include the following applications: - Fireplaces, foundation walls, chimneys, retaining walls, showers, archways, columns, lintels, and stairways. The system includes both horizontal and vertical overlay systems that require minimal preparatory work compared to modern products currently available. Has advantages over natural stone, manufactured stone, and other building materials. The Wall and Floor Systems offer decreased labor costs, insulative properties, fire protection, artistic and creative possibilities for custom designs, The system reduces the labor intensive prep work necessary for other systems. Flexcement applicators install the product directly onto existing surfaces. It can be applied over concrete, masonry, tile, painted surfaces, drywall, Styrofoam board, and wooden surfaces. Installation requires application of Flexcement exclusive Primer, followed by application of the Modifier enhanced dry mix as a finish, or stamp coat. The material is then stamped with one or more of our exclusive stamps, designed to replicate natural stone. QUICK BRICK : THE NEW REVOLUTIONARY BRICK LAYER APPLICATION SYSTEM! You can determine your own brick size and design, patterns and colors with Quick Brick. Without any application problems, easy and fast QUICK BRICK is now available for your all projects. Easy application, various designs and colors, flexible choices
Weiterlesen...
Weiterlesen...
