archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Channels designed specifically for swimming pools, changing rooms, shower rooms; the discharge of water takes place through a narrow slot of up to 8 mm.
They are constructed in AISI 304, but especially also in AISI 316 for use in environments with high levels of chlorine.
Manufactured with flattened edges to make the drainage channel less visible in the flooring,
For this reason, the collection gullies are also of smaller dimensions; the inspection gullies have a siphon and are equipped with a filter basket.
They are fitted with flanges along the perimeter to enable a perfect seal with the waterproofing gasket.
The system is highly versatile, and there are no constraints concerning piece length or positioning of the gullies.
The assembly of the various gullies and the channels is provided for by means of flanges with silicon seals that are secured with bolts to ensure that they remain water-tight.
Weiterlesen...
Weiterlesen...
