archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
New hinge for doors with a simple counter fitting assembled in a flash FLASH XL is the counter-fitting hinge studied to realize doors with window profiles. Easy and quick to install, it does not require any type of profile working. The fixing is made with plates, as a standard window hinge, without making the dril-ling typical of the door hinge with front application. In this way the time of installation of the hinge on the profile is strongly reduced. FLASH XL enables to realize doors with loads up to 100 kg. The dimensions of the hinge confer max. stability to the window, door also in presence of door closing devices.
Weiterlesen...
Weiterlesen...
