archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Fläkt Woods new Chilled Beams set to become the stars of the future Fläkt Woods has launched two new active chilled beams, the Stella and Astra, which perfectly complement their comprehensive range of existing chilled beams. The new active chilled beams form part of the new IQ-STAR range and comprise of an exposed Multi Service chilled beam (Stella) and an Integrated model (Astra). These new models are the result of over 18 months of research and development to provide demand controlled indoor climate directly via the chilled beam. By integrating its knowledge of Indoor air climate (IAC) within its product development program and working closely with designers and architects, Fläkt Woods have developed systems dedicated to provide some of the most efficient and green solutions currently available within the Building Services Industry. Both beams are designed for the modern office life, satisfying the demands of increasing productivity and providing a working environment that is comfortable and well-adapted to the needs of the workers. Aesthetically created with unique smart functions, flexible construction and energy saving modes they are certain to be the future stars of the market. Demand controlled indoor climate provides desired ventilation based on the actual occupancy of the room. It increases indoor air quality and saves energy normally wasted in ventilating unoccupied spaces. This can be applied to areas where there are frequent changes in occupancy, such as conference rooms, board rooms, cafeterias etc. Research has proved that demand controlled indoor climate can reduce ventilation as well as heating and cooling loads by 10%–30%. IQ-STAR – ASTRA Flexibility, sustainability and energy efficiency are the guiding values of our integrated ASTRA chilled beam. Astra has the groundbreaking Boost function. The air flow is adjusted automatically, depending on the level of CO2 in a room. Fläkt Woods' range of chilled beams with its unique variable air flow function, Flow Pattern Control function provides high flexibility both in new buildings or refurbishments. The air flow can be directed up to 45 degrees through integrated vanes. When increased air flow is required, the vanes can be adjusted into different directions, to increase comfort. Integrated functions include sprinklers, smoke detectors and modern down lighting. New regulations such as Part L2 of the Building Regulations naturally lead to more water based cooling systems being designed, as the energy needed to provide the cooling requirement is less than cooling through the air. Indoor air quality has also become a priority, as clients and end users demand better working environments for their staff, knowing that this will lead to higher productivity and less sick leave. For further information, please contact: Lennart Wass Product Manager DCC, Fläkt Woods Mail: lennart.wass@flaktwoods.com Tel: +46 70 566 4001 Anders Martensson Global Communications Manager, Fläkt Woods Mail: anders.martensson@flaktwoods.com Tel: +46 36 193 330
Weiterlesen...
Weiterlesen...
