archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
News Release For Immediate Release Contact: Kim McAdams FC Lighting 800.900.1730 kmcadams@fclighting.com FC Lighting Introduces Square LED FCSL540 ST.CHARLES, ILLINOIS—August, 2008—FC Lighting, a leading manufacturer of commercial standard and customized lighting products, introduces a LED step light with an expected life of 50,000 hours. The new FCSL540 die cast square step light can be used in vertical mount applications in step risers, side walls, or in-ground, in the step itself for masonry applications that can be installed during concrete pouring. The step light is often used as a decorative element in facades. While the step can use fluorescent, incandescent or HID lamping, it is the LED lamping that has a service life of 50,000 hours, or approximately 20 years. Durability is assured with die-cast aluminum heavy wall construction. FC's high-grade TGIC super polyester powder-coat finish is available in standard black, white, or any custom color. White, color or color-changing LEDs are available. FC Lighting, Inc., is a leading manufacturer of standard and customized architectural lighting products for retail, hospitality, educational, government and other commercial installations. Headquartered in Addison, IL (USA), the company distributes its products globally. For further information about FC Lighting and its broad line of lighting products call 800-900-1730 or visit the company's website at www.fclighting.com. .
Weiterlesen...
Weiterlesen...
