Extenzo Multiplies the Benefits
archiexpo
12. August 2008
An Easy Ceiling to Install, an Easy Ceiling to Live With, Extenzo Multiplies the Benefits A decorative ceiling with a world of creative possibilities - an exceptional choice of colours and performance qualities - creation of horizontal, vertical or inclined surfaces - creation of curves and volumes - creative mastery of lighting effects: diffusion, depth, reflections… - adaptable to all styles of architecture An easy ceiling to install - simple preparatory work, fitting in a few hours - a dry worksite, no smells, no dust - no drying time required - premises immediately available for use An easy ceiling to adapt - removable locking system patented by EXTENZO® - possibility of adding lighting points, air vents, detectors, etc - access to all pre-existing pipes and cables - pipes and cables can be added without any finishing work - easy to put up and take down A decorative ceiling with a perfect finish - exceptional finishing - optimum tension for a matchless, perfectly flat surface - a feeling of balance and harmony - integration of lighting and other accessories - discreet concealment of pipes and cables, whilst maintaining ease of access - the air pressure is balanced above and below the stretch ceiling, to achieve greater stability Extra comfort - improvement of temperature comfort by means of an insulating cushion of air - excellent results when combined with thermal insulation - improved acoustic comfort, a warm, protected atmosphere - creation of high acoustic quality space with perforated stretch ceilings - visual comfort, an impression of greater space, a feeling of well-being - dust-tight
Weiterlesen...
