Engineering Detailing / CAD | Allplan Engineering
archiexpo
12. August 2008
Allplan Engineering: simplified engineeringBeing an efficient tool for the production of overview and detail drawings, Allplan Engineering manages the most complex situations. Beside the general requirements of classical CAD formwork and reinforcement and of the basic technological Nemetschek products, Allplan Engineering disposes of very original functionalities: the "macro command" module and the technical symbol catalogues make it possible to automatically repeat complete sequences of commands with variable parameters.Changing parameter settingThe evolutionary parameter setting: all the graphic entities can be linked. Thus, if a dimension is modified, the reinforcement steel automatically follows the formwork, the constructive provisions and the parts list are reactualized without intervention of the designer.Formwork : a CAD dedicated to the building tradeBeyond the traditional functionalities, Allplan Engineering proposes new modules:- Use of predefined structural components : envelopes, columns, slabs, hoppers...- Roofs modellers, staircases- Floors design- Automatic elevations and cuts- Associative quotation- Exploitation of the bills of quantities- Realistic design and animation of scenesReinforcement: simple or complex clicks for a projectAllplan Engineering automatically generates reinforcement and proposes a reinforcement catalogue. This catalogue is already very extensive and can easily be enriched. From the formwork plan on, the positioning of reinforcing steel is carried out automatically in the various views describing the element (elevations, cuts...).Allplan Engineering does not have a formal limit on the complexity of reinforcement, either regarding the management of the forms (TS, sheets, bars, frameworks...) or the optimisation of steel bars.The assessment and the retrieving in the parts list are also automatic and meet the practical needs and standards of the respective country.Assets:- Use of a extensive library of welded bars and meshes- Automatic division of TS panels- Design of bars in real sizes- Immediate generation of detailed steel lists- Interactivity of views- Check on overlapping of reinforcementOther characteristics:- Automatic recognition of shapes- Automatic reinforcement of structural components: staircases, reinforcements of hoppers, connections of envelopes- Summary table of all reinforcing steel and corresponding dimensions- Perspectives- Associative dynamic quotations- Parts, surfaces, lists of quantitative data- 3D modellers, sites, staircases, roofs and frames- Synthesized images- Working in network- Symbol library
Weiterlesen...
