archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Decorative and economical unit with “EZ” install back plate feature has modern appearance and low maintenance. It is ideal for commercial, institutional, and industrial facilities where economy, appearance, and ultimate ease on installation and maintenance are desired. Also ideal when a low profile unit needs to meet limited space requirements, and any space requiring back-up emergency lighting. Features: - Completely self-contained - Fully automatic operation - Compact, low profile design in neutral finish - Universal mounting plate with “EZ” quick connect for rapid labor saving installation - Push to test switch - 6-volt premium grade, pure lead, calcium, maintenance free battery with 10-year expected life - Environmentally-coated, solid state charger - Automatic low voltage disconnect (LVD) protects battery from deep discharge - Universal transformer for 120 or 277 VAC operation - Standard with two fully adjustable 5.4 watt, glare-free lighting heads - Injection molded, V-O flame retardant, high impact, thermoplastic housing - Charge rate/power on LED light indicator
Weiterlesen...
Weiterlesen...
