Edge Lit LED Light Panels
archiexpo
12. August 2008
Super Thin LED Design 8mm or 0.35" Innovative LED Technology Can be customized to any dimmension cULus Listed E325925 Eco-Friendly Energy Efficient Light Source Low Voltage Low Wattage Endless Application Potential LED light panels are constructed from high performance optic acrylic sheets used in LCD displays (not the regular acrylic sheets) with the patented and CNC machined “V-cut” light distribution grids on the back.With LEDs and heat-sinks embedded in the light distribution sheets, LED light panels are as thin as 8mm (0.31”), as bright as 2000-9000 Lux evenly distributed over the panel, and can be easily integrated into your custom lighting application or other existing snap frames to build custom light boxes for store or indoor/outdoor lighting applications. LED Panel Lighting is designed to emit a bright, even output of light across the entire surface of the fixture. Edge lit with highly efficient LEDs, the light travels from the edges of the panel along laser engraved channel etched into optical grade acrylic, to the centre of the panel. The patented technology allows each panel to be brightly illuminated across its entire surface without dark spots.At a depth of only 8mm, the LED Light Panel is the perfect solution for bright, even illumination on any project. Maximum dimensions of each panel are 96” long X 48” wide. For larger applications placing panels side by side will create continuous even light source.Custom shapes, letters, logos and cut-outs are all easy to achieve with our LED Panel lights. Our precise cutting CNC machines are able to work to your exact specifications, providing creative solutions to your lighting, millwork, signage and display projects
Weiterlesen...
