Ecoflo®, the most recommended and installed septic system!
archiexpo
12. August 2008
A residential solutionThe most recommended, most installed and most proven septic system! Ecoflo ® is one of the most recommended compact wastewater treatment systems on the market. Its performance during certification tests performed since it was first marketed is always well above requirements. It's not surprising that more than 40,000 families have made it their own! So many advantages! Independent, compact and permanent System ideal for new construction and replacement of failing systems Space required 2 to 4 times smaller than conventional systems No electromechanical components Best warranty on the market Ecoflo ® – A simple operating principleWastewater from the septic tank equipped with an effluent filter is directed to the fibreglass or concrete Ecoflo ® and spread over the entire surface of the organic filter using a mechanism with no electromechanical components. With Ecoflo ® you'll enjoy more of your lot! The Ecoflo ® system is an excellent alternative to a standard disposal field. It can be adapted to all types of sites and often significantly reduces the surface area needed to install an individual wastewater treatment system. Ecoflo ® blends into your landscape with only the access lid showing above ground. You need:Septic tanks Effluent filters Pumping stations
Weiterlesen...
