archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The DOMUSPLAT pantograph hydraulic lifting platform successfully removes the architectural barriers in case of reduced rises (up to 2 metres).It is the ideal solution for overcoming just few steps.The platform is very easy to operate by means of a standard pushbutton panel, on landings and onboard, with low voltage supply (24 V).Gates and/or landing doors can be manually opened and are provided with a safety lock.Standard supply includes manually operated emergency down travel and maximum pressure gauge in order to avoid platform overload.The upper platform is covered with non-slipping material.Platform with enclosed shaftIf an enclosed shaft with landing doors for user's safety are not already available, DOMUSPLAT can be supplied with section iron and glass or sheet steel cladding.Platform without shaftWhen it is not possible to build an enclosed shaft with landing doors, the DOMUSPLAT model “without shaft” is available. On the free sides under the platform a folding protection is installed, which prevents from accessing the area below, thus avoiding the risk of crushing. The Domusplat dimensions increase slightly when the folding protection is installed. All systems can be provided with emergency down travel directly operated from the platform.
Weiterlesen...
Weiterlesen...
