archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
- Wall-hung atmospheric boiler with traditional combustion.- Compact heat exchanger made completely from copper (FERROLI patent)- Large multifunction backlit graphic display for easy and correct setting of the parameters.- The DOMITECH boilers are fitted with an antifreeze device on the central heating circuit.- Instant production of domestic hot water.- The DOMITECH boilers can be connected to any type of room thermostat, timer thermostat and to an external probe.- Electronic flame modulation in both central heating and domestic hot water mode.- Fitted for solar system.ADVANTAGES OF THE DOMITECH- Site of installation: F models
utdoor installation in partially sheltered places down to -5°C as standard and down to _15°C using the optional frost protection heater kit.- Modulating heat input for both central heating and DHW operation, managed by the electronic board with microprocessor.- Maximum reliability and safety.- Extremely compact dimensions.- ECO/Comfort function in domestic hot water mode.- 3 star efficiency certification according to 92/42 EEC(forced draught room-sealed models).- Available in the LPG version.
Weiterlesen...
Weiterlesen...
