archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Available in six-channel and twelve-channel versions, the DMX2CC enables DMX control of high power LEDs (1W and 3W) using a constant current dimming method, ensuring flicker-free and smooth dimming, especially for environments such as television studios. A DMX out port repeats and amplifies the DMX signal for convenient daisy chaining in projects where one DMX input signal must be distributed among several of these devices. Additionally, a self-diagnostic test function prevents damage to the unit and LEDs caused by incorrect wiring, open or short circuit, and overheating. DMX2CC is easily set up with auto and manual DMX addressing modes, and conveniently mountable inside equipment racks using standardized 35mm wide DIN rail.Smooth, flicker-free dimming - Linear, continuous current dimming method of LEDs ensures flicker-free and smooth dimming, especially for environments such as television studios. DMX out port to repeat and amplify the DMX signal – Multiple DMX2CC devices can be conveniently daisy chained to distribute the DMX signal among each other, respectively. Self-diagnostic test function – Prevents damage to the unit and LEDs* caused by incorrect wiring, open/short circuit, and overheating. DMX auto/manual addressing – Use auto or manual addressing to quickly specify DMX channels. DIN rail mounting – Easy mounting inside equipment racks using standardized 35mm wide metal rail.
Weiterlesen...
Weiterlesen...
