Diathonite evolution
archiexpo
12. August 2008
Thermal premixed plaster, fibre-reinforced with cork (gran. 4/5 mm), clay and diathomeic powders. Natural compound ready to use, to create external thermal coatings and dehumidify suitable both for inside and outside. ADVANTAGESInsulation against cold and warmth (it guarantees good dynamical parameters of displacement, upto 12 hours depending on wall's features)Optimum air flowsResistant to fire class 1Eco-friendlyNo double-layer wallVery fast building system (thermal brick + plaster)Doesn't crack on brick work between supporting pillars100% Usable without wasteVery fast application (pump application)APPLICATION by PUMP Use spray plaster machine that automatically supplies the correct water dosage for the paste (do not add other inert or binders).Load the content of the sacks inside the hopper and regularize the flow meter according to the machine to be used.Regularize the flow meter at 440-460 R/hPump features:Conical tuyereHole of 18 mmTube of 35 mm
Weiterlesen...
