Diapason - Light made orientable
archiexpo
12. August 2008
Thanks to a gyroscopic principle, Diapason can be easily positioned in any direction in order to highlight architectural details. A revolving stop locks the fitting in any position. Different reflectors are available depending on the light source. These reflectors are easily installed by being clipped into the housing after the luminaire installation and connection. A wide range of light sculpting accessories is available such as dichroic filters, lenses and louvres. The fixture can be directly mounted with a round or square base, in track systems or even with a M10 nipple for special applications. It is delivered in silvergrey, black or white wet paint. This fitting is the basic element of the Diapason series and is developed for QT12-ax, QR-LP111, QPAR30 and HIT-TC-CE. When required, it is equipped with a cooling profile which ensures sufficient heat dissipation. Reflectors required for QT12-ax and HIT-TC-CE can be easily installed and allow lighting designers to choose among different beam angles. Furthermore, beam angles can be shaped by a variety of complimentary accessories.
Weiterlesen...
