archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The Delta suspension system allows for easy placement and removal of all ceir open cell ceilings.Thanks to its special suspension components, the Delta suspension system allows for demounting of panels from below, offering a superior accessibility to the plenum for maintenance crews after installation.The suspension is concealed giving a trackless appearance and each panel is fully downward demountable.Using special springs, the panels are hanged to suspension channels, which placed over and connected by couplers, will disappear when looking at the ceiling from below.The panels swing down and remain suspended at full length. Upon request, hinge-down is possible from the short side (600 mm.) or the long side (1200 mm.) too.See our VIDEO.Delta suspension system is specifically designed for Deltaceir and Deltaceir Line ceilings. However, it can as well be used for other Ceir open cell ceilings (Tetrál b, Tetrál Inverse, Tetrál line, Reflex, ect.).
Weiterlesen...
Weiterlesen...
