Decentralized Ventilation Systems - Type FSL - U - ZAB
archiexpo
12. August 2008
The main components of the system besides the casing lined with acoustic and thermal insulation are the fan, motorised shut-off damper and backdraught damper. It also includes the supply and exhaust system as well as the heat recovery unit with a bypass and the heat exchanger for tempering the supply air.As a comfort conditioning supply and exhaust air unit with integrated heat recovery, this is a high quality replacement for a central ventilation plant.Static heating is possible when the ventilation is switched off.The type FSL-U-ZAB decentralised under floor units are combined supply and extract air units for ventilation, heating and cooling of individual rooms or complete buildings. Before the supply air enters the room it is filtered as well as heated or cooled to provide the required supply air temperature. The room return air passes through a heat recovery unit before being discharged to the outside. The heat recovery unit is used to condition the supply air thus minimising the basic energy requirements of the system .
Weiterlesen...
