archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
After the wall layout is defined in D-Wall, you can work through the individual walls and fill them with the supporting structure of timbers, boards, and panels by using D-Wall Professional. The timbers are automatically cut to size and joined according to your definitions. All wall to wall connections and possible interference from other building parts in the 3D model are obvious and can be checked any time.Along with the building design, the information for your production papers is created while you work: full material take off lists for timbers, boards, and panels; lists for hangers and fixtures; lists with the number of joints and processes (mortises, tenons, bird's mouths, bevel cuts, chamfers, drillings …)
redimensioned shop drawings of single walls; and drawings for production and assembly.Machine files are also created, so at any point you can output to NC/CNC machines to have your timbers and panels cut for you.
Weiterlesen...
Weiterlesen...
