"Cube", the new shelf modular design
archiexpo
12. August 2008
Teebooks ready to launch a new shelf design.
It’s the easy idea of a simple cube with a bottom which allows the shaping of a bookcase in the desired size, height and width.
You can put it on a wall or use free standing as a divider space.
The basic module is a*black or white*steel cube (20/10 mm in thickness)*34 cm high,*45 cm wide, and only 25 cm deep.
TEEbooks, Die Emotion des Designs einfache, nützliche und nachhaltige
Weiterlesen...
