archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The new Relax Lounger for the CONODUO bath instantly turns the designer bath into a small wellness oasis. Relaxing on the fi ne fabric, you'll feel as if you're lying on the deck of an elegant yacht. In addition to its design qualities, the Relax Lounger offers a high level of functionality. It is made up of three pieces of two sections each, making it possible to use the Relax Lounger as three separate boards with varying applications: for example as a shelf while lying in the bath, or as a mattress to recline on. When the three boards are placed together on the CONODUO, they can be connected securely, forming a large, stable surface that sits fi rmly on the bath. A further connection between the Relax Lounger and bath can be created by fi xing attachment buttons to the bath. This allows even already installed CONODUO baths to be retrofi tted with the Relax Lounger. The Relax Lounger supports up to 130 kg and is available with a special cushion. Cushion dimensions: 40 x 23 x 9 cm. Relax Lounger dimensions: 180 x 80 cm, 190 x 90 cm.
Weiterlesen...
Weiterlesen...
