ColorPlus® Technology
archiexpo
12. August 2008
James Hardie Siding Products with ColorPlus® Technology require virtually no maintenance. Over 15 years, that adds up to saving you thousands of dollars in painting and repair costs. Our complete solution gives your next project the same durability, color consistency and value that you can expect from James Hardie. Our finish warranty guarantees your color will not crack, chip or peel for 15 years. Over 41 quality checks are made throughout our proprietary manufacturing process to ensure the quality of the substrate, the texture and the finish. No other manufacturer can match our demanding quality standards. Committed to the environment, James Hardie Siding uses only the finest raw materials to manufacturer our sustainable products. Considering the alternatives? Compare the benefits of James Hardie Siding Products with ColorPlus® Technology to filed applied paint options, especially on larger buildings. Color Options We provide you with a choice of today's modern colors to suit your design needs. With the help of color expert and PhD, Leslie Harrington, an exclusive color palette was selected for each region. Colors were chosen to cater to the cultural, architectural and environmental factors of each area. To find out what colors are available for your project location click here. A Green Technology James Hardie Siding Products with ColorPlus® Technology are eco-conscious on multiple levels, from materials and manufacturing, to transportation and installation. Our unique factory-finished ColorPlus Technology delivers pre-painted siding products to your job site. This eliminates the release of harmful VOCs into the air during exterior painting, and guarantees that you or your client won't have to repaint for at least 15 years, preventing further environmental contaminates. Longer lasting materials not only require fewer resources for replacement but also reduce maintenance and repair costs. Our nine strategically located manufacturing facilities support regional economies and reduce the environmental impact caused by excessive transportation of materials. Most of the raw materials used to make James Hardie Siding are extracted and processed near each manufacturing facility. The ColorPlus® Process James Hardie Siding Products with ColorPlus Technology combine the best substrate, the best paint and the best process to provide building designers and owners with a superior siding solution. To ensure ultimate paint adhesion and consistency, James Hardie Finished Siding doesn't leave our facilities and is kept in a controlled environment throughout the entire manufacturing process. We are the only company to manage our product from the initial mixing of the cement to finish completion in one facility. Over 41 quality assurance checks are made throughout the process to ensure that each board meets James Hardie's superior standards. ColorPlus Technology was engineered because existing technology did not meet our requirements. Every board is pre-conditioned to maximize paint adhesion before our multi-coat, baked on finish is applied. Throughout the entire manufacturing process, automated technology virtually eliminates human error. Our proprietary laminate technology protects the finished siding from the time the board leaves our factory to its final installation. What does this mean for you? A guarantee that we produce the highest quality, most consistent product possible. A finish that lasts up to 8 years longer than traditional paint, providing peace of mind and saving thousands of dollars in painting costs over 15 years.
Weiterlesen...
