archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
• Extra thick 1/4 inch ABS floor that helps keep heat in and critters out • 240 Volt pump has the ability to operate at an Equivalent Rated Performance of 5 horsepower to be more efficient in airflow and to help achieve perfectly balanced water pressure through each jet • Stainless 5.5 kW Heating System warms water quickly and efficiently, and maintains even temperature • Elevated High Performance Plumbing gives each jet its own water line, elevated mount helps prevent freezing in the pipes • Turn on air injected jets separately or in conjunction with the High Flow Hybrid Pumps to achieve the desired massage experience • Scented cartridges simply drop in to the integrated topside receptacle and mix with the air injection system • Ozone purifier removes unwanted contaminants from the water via O3 oxidation • Cascading water fall feature creates ambiance and a soothing atmosphere via a simple turn of its own freestanding control valve • 100 sq.ft. of Forever Flow Filtration powered by a 24/7 circulation pump • Luxury headrests • Soft-touch digital buttons that operate everything from the standard hot tub functions (pumps, lights, temperature) to extras such as the clock, and economy mode • LED Safety and Mood Lighting light with multiple colors and blinking options • 5 inch tapered heat shield cover which allows more heat retention and absorbs less humidity • Seats 3 • 37 jets • Shell dimensions: 87” x 64.75” • Height: 34.5" • 160 gallons • Weight: full - 1970 lbs, empty - 635 lbs
Weiterlesen...
Weiterlesen...
