archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
COAX thermal store The COAX thermal store provides high-efficiency solar heating and hot water storage through the power of the sun. According to research by Consolar there are no other thermal stores for hot water in this class on the European market that come near its performance. Usage - Excellent for the use in family homes - Ca. 60 - 80 % solar energy savings on your annual domestic hot water bill. - Compatible with all existing or new boilers Advantages - Ca. 10 - 30 % higher energy savings in comparison with conventional installations - High performance heat exchanger with 50 % higher heat release in comparison with standard models - Patented insulation system ensures ca. 50% less heat loss - The COAX 200 is small and compact saving space due to its height of only 1 meter - Considerably longer storage of solar heat in comparison with conventional installations - Very environmentally-friendly due to novel LEEPS insulation foam
Weiterlesen...
Weiterlesen...
