archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
CLIX Roofing and Uni-Solar present to the market new product.HOT DIP GALVALUME 55% ALUMINUM-ZINC ALLOY COATED STEEL, ASTM A792 CQ (DX51D), AZ- 185, regular spangle, Anti-finger coat, dry and uncoiled. Thickness 0,6 mm.Ñertified : ISO, SITAC,TUFHigh Temperature and Low Light Performance 20 Year Warranty on Power Output at 80%Quick-Connect Terminals* and Adhesive Backing Bypass Diodes for Shadow Tolerance= UL 1703 Listed to 600 VDC ®IEC 61646 v1 certifiedRated Power (P): from 68 to144 Wp Production P .X Tolerance: ± 5 %Dimensions: Length: from 3118 mm to 5600 mm (216), Width: 485 mm (15.5"), Depth: 4 mm (0.2"), 16 mm (0.6") including potted terminal housing assemblyWeight: 7.7 kg (17.0 Ibs) or 6,7kg per m2 CLIX UNI-SOLAROutput Cables: 4 mm2 (12 AWG) cable with weatherproof DC rated quick-connect terminals*560mm (22") length.By-pass Diodes: Connected across every solar cellEncapsulation: Durable ETFE high light-transmissive polymerAdhesive: Ethylene propylene copolymer adhesive-sealant with microbial inhibitorCell Type: 22 triple junction amorphous silicon solar cells 356 mm x 239 mm(14" x 9.4") connected in seriesUOL Lissted by Underwriter's Laboratories for electrical and fire safety (Class A Max. Slope 2/12, Class B Max. Slope 3/12, Class C Unlimited Slope fire ratings) for use in systems up to 600 VDC. Flexible .wStr3rd Ccnl gUrainn Photovoltaic laminate with potted terminal housing assembly with output cables and quick-connect terminals.New or qualified new roof installations `Installation by certified installers only Installation temperature between 10 °C - 40 °C (50 °F -100 °F) No-GlassMaximum roof temperature 85 °C (185 °F) Minimum slope: 5/8:12 (3°) Maximum slope 21:12(60°) Membrane: Select EPDM and TPO substrates from approved manufacturers only
Weiterlesen...
Weiterlesen...
