CL600 gives convenient access control at John Radcliffe Hospital
archiexpo
12. August 2008
Facilities Managers at The John Radcliffe Hospital have specified Codelocks to provide convenient, flexible access control solutions for high traffic areas within the healthcare facility. The new CL600 mechanical lock with the Quick Code keypad recoding function has been installed to provide a heavy duty, low maintenance solution for doors in constant use throughout the hospital.Traditionally, code changing on mechanical locks has required the lock to be partially disassembled and physically removed from the door, however the new-patented design of the CL600 allows the code to be changed from the front via a key. The new lock is of particular benefit to commercial users such as hospitals, schools and large businesses as it provides a level of functionality previously only available on electronic locks, dramatically reducing maintenance time and cost.Neil Hemmings, Estates Supervisor at the John Radcliffe Hospital commented, “The new CL600 from Codelocks ticks all the boxes for us as we required a high quality, robust lock with Quick Code change to replace existing locks that were not able to endure the constant, everyday use on site. We have now specified a number of CL600 locks in various locations throughout the hospital after seeing impressive results following a trial period. The on-door code changing function is a major benefit for large sites with multiple installations and will dramatically cut down maintenance time for busy hospital estates and facilities managers.”Codelocks CL200, CL400 and CL4000 ranges have also been installed in the hospital, the CL4000 electronic lock providing the convenience of keyless access to administrative and nursing staff as well as a key over-ride feature for management functions and emergency situations.Neil Hemmings said, “Codelocks are much more time efficient in terms of maintenance, easy installation and simple keypad recoding. The mechanical and electronic locks provided by Codelocks have made a real difference with regards to maintaining access control on the site, both myself and the hospital staff are extremely pleased with the results.”Codelocks' range of mechanical and electrical locks provide solutions for a wide range of commercial and domestic door control applications including schools, hospitals and local authorities by giving greater control of access on multiple doors.Codelocks Tel: 01635 239645sales@codelocks.co.uk www.codelocks.co.uk.
Weiterlesen...
