archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Pressed, moulded 12 mm thick beech wood multilayer seat and back panels. Pressed, moulded 6 mm thick beech wood multilayer upholstery panels, padded with injected polyurethane, density 55 gr/lit, thickness 60 mm, fire retardant and HCFC free. Polished die-cast aluminium armrests. Pressed, moulded beech wood multilayer armrest tops, 10 mm thick, padded with injected polyurethane, density 55 gr/lit, thickness 30 mm, fire retardant and HCFC free. Polished die-cast aluminium seat/back joint for the version without armrests. Forward pivot tilting mechanism with 5 locking positions, tension adjustment with knob. Steel swivel plate. Five-pronged polished die-cast aluminium base. Pivoting nylon castors, diam. 50 mm with steel pin for easy insertion. Nylon gliders with steel pin for easy insertion. Four-leg chromed steel base with adjustable nylon feet.
Weiterlesen...
Weiterlesen...
