archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Discover the new CINEPAR 18/12KW, the most powerful HMI fixture in its class. Features : - Upgrade your power, downgrade your problems ! - Standard GX 51mm 12/18k lamp socket - New yoke saver disc brake system - Strike with any existing 12/18k ballast on the market - No married ballast or special wiring - The first of its kind: 625mm - 3 pieces lens set: Frosted Fresnel, Medium, Super wide - 32 ½” long - 31” tall / weight 130lbs (82.5cm long - 79cm tall / weight 59kg) - Thanks to its light weight and small dimension, only two operators are required to lift the head
Weiterlesen...
Weiterlesen...
