archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
For each type of KORAMIC tile there is a complete range of shaped ceramic tiles, such as ridge tiles, verge tiles and many more, to guarantee the perfect appearance of the roof. Matching accessories Modern architecture is taking new paths and the many shaped parts available allow you to create the perfect appearance of your roof and façade. From a technical point of view, the appropriate accessories ensure the creation of a perfect roof. Each type of clay roof tile has its own accessories, some 100 parts in all, which KORAMIC also supplies in the colour and surface structure that match the selected clay roof tile: Ridge tiles / verge tiles: half-round or angled ridge or verge tiles create, for example, a technically aesthetic unit at the join between vertical façade surfaces and the roof tiles Kink tiles: so-called kink tiles are used for the connection of the vertical façade to the inclined roof, providing a flowing transition in one and the same material. Eave tiles, mono ridges, steam exhausting tiles, ventilation tiles, etc. The accessories for the clay roof tiles have their own special function: they fulfil both aesthetic and functional tasks. The correct application and assembly of these accessories must be ensured. But do not worry - your roofer knows exactly which type of accessory he needs for which type of roof.
Weiterlesen...
Weiterlesen...
