Ceiling mounted fluorescent luminaire "SP SERIES"
archiexpo
12. August 2008
- Shallow profile minimally penetrates ceiling.- Available in semi-recessed or fully recessed versions.- Extruded aluminum housing and fascia.- Staggered lamps are standard.***Specification Data***:Housing: Housing and vertical fascias are extruded aluminum. Internal wiring trays are 20-gauge,cold-rolled steel.Mounting: Recessed perimeter wall wash in 8-ft., 6-ft., 4-ft., 3-ft. and 2-ft. sections.Shielding: Extruded matte white acrylic lens snaps into housing.Corners: 90-degree inside or outside corners.Housing finish: Standard finish: matte white.Lamps: Standard 6" stagger (1) or (2) T5, T5HO or (1) T8 (in cross section). Lamps provided by others.Ballast: Electronic (limited to slim profile case size). Please specify voltage.Certification: U.L. listed, I.B.E.W. (Local 3) Union made in the USA
Weiterlesen...
