archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
The designer Cecilie Manz launched her co-operation with Lightyears in 2005 and with the introduction of Caravaggio Table and Caravaggio Floor her characteristic pendant lamp has come down on to the table and the floor. The new lamps complement the swinging pendant lamp when they are in the same room, while at the same time they are elegant design pieces that will always be able to stand alone. Both the table lamp and the floor lamp are made of metal with a lacquer finish. The characteristic shade is high-gloss lacquered, while the foot and standard have been given a dull lacquer finish. A flexible tube, which is hidden by the shade, has been mounted on the standard which makes it possible to tilt the shade, and with it the light cone, up to 40 degrees. This function makes the lamps more flexible and functional as light sources, so that they can be used, for example, as working lights. At the same time an exciting asymmetrical look can be achieved when the shade is tilted. The table lamp is available both on a foot and as a plug-in, with the lamp located directly in the table. All three versions are available in black and white.
Weiterlesen...
Weiterlesen...
