BRIO®WM50 powerful lighting !
archiexpo
12. August 2008
Water is even clearer with this lighting ! with a wide scattering angle of 120°, WM50 assure ensuring the best lighting for your pool. Ecologic : made up of high power LEDs, 30 000 hours lifespan : No more breakdowns or heavy duty maintenance to change your pool lamp !Very high efficiency lighting : Unequalled power of lighting.Permanent lighting without problem of overheating.Energy saving : Low power consumption in comparison with a standard light. Very long lifespan (up to 100 000 hours). Change your pool in a world of feeling ! Possibility to rhythm the color change with music (input audio). 7 different colors.Brio®WX LED bulb50W lightingsingle-colouredFits in standard niche PAR56: you can replace the existing bulb without modifiying your installationCompletely watertight IP-68
Weiterlesen...
