BoxGrills offer features which uniquely benefit the 'built-in' concept
archiexpo
12. August 2008
All four sides are double-skinned, greatly improving guest safety and chef comfort. This also contains heat efficiently within the grill, ensuring as little as possible is transmitted to surrounding construction, or lost to the environment. BoxGrills can be stripped out within a couple of minutes, without the use of tools. Scheduling cleaning and disinfecting in-situ becomes an easy option. The heavy griddle is milled cast steel, and the controls and flame safety devices are brass. Everything else, including the barbecue grill which is made in V-shape, channels 80% of the fat into the full-size drip tray in front of the grill. It is solidly made from quality stainless steel. The burners (2-4-6) can be lighted separately, and adjusted to control the grilling process. A piezzo electric ignition is forseen for each burner separately. Lavarocks are placed above the flame covered heat exchangers. Each model can be placed on a wheelbase with adapted height.
Weiterlesen...
