archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
All the benefits of glass plus integrated solar power.Integrated solar modules from transparent to opaque ASI® Glass elements are available in various design options. Depending on the application and the desired architectural appearance, this flexibility always allows the designer to optimize the integration of solar panels into the building.Engineering with ASI® GlassEffective with conventional glazing systemsThere are special solar cell encapsulations available for every application, for example, laminated glass for overhead applications. Used horizontally or vertically, ASI® Glass solar modules fulfill the requirements of the construction industry and can be used with almost all conventional framing systems. Static load requirements can be met by changing the type and thickness of the glass panes. The encapsulation of ASI® solar cells in laminated or double-glazed constructions makes use of proven technology and manufacturing methods.
Weiterlesen...
Weiterlesen...
