Bin Fridge
archiexpo
12. August 2008
The BinFridge is designed specifically for the safe storage of household waste and eliminates the build-up of most harmful bacteria as well as significantly reducing the smell generated by waste. With 9 million homes now having their bins emptied only once every two weeks - leading to increased bacterial build up and even more unpleasant smells - the BinFridge is the perfect solution. Easy to use - you simply wheel your wheelie bin into the BinFridge with its lid open, lock your wheelie bin in using the integrated locking system and add household waste through a hinged and insulated top loading hatch. Your waste is then stored at 5°C, the temperature necessary to eliminate the build up of most harmful bacteria. Available in sizes to house one, two, three or more wheelie bins – the BinFridge is perfect for all household types - including apartments where individual flats can have their own section in a large BinFridge. Also ideal for restaurants, sandwich shops and cafes where the amount of moist waste is significant. It's ideal for anyone wanting to reduce the smell and build up of bacteria in their wheelie bin.
Weiterlesen...
