archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Starline has over 35 years of experience with producing automatic slatted pool covers. Starline Roldeck is market leader in prominent markets in Europe. The Starline Roldeck not only covers the pool and decreases costs for heating and maintenance, it also contributes to a safe swimming environment, especially when a child-safety lock is installed.The slats of the Starline Roldeck are available in rigid PVC and super strong Polycarbonate, which is used in the automotive industry as well. The Roldeck can be installed above ground or in-ground, using different sorts of underwater installation. The winding mechanism can be protected with Roldeck Protect, an anti-corrosion coating for pools with salt, saltwater, or high levels of chlorine.The drive mechanism for the Starline Roldeck can be an external motor or an in-roller motor which is fully integrated in the roller. These engines provide between 100 and 1000 nm depending on the size of the Roldeck. The Starline control panel operates the Roldeck with just a few buttons. The control panel comes with connections for the child-safety lock, counter current, filter pump, pressure measurement, and an extensive error code diagnosis system which makes malfunctions easier to recognise for servicing. The Starline Roldeck is suitable for all types of pools; concrete, liner, steel, fibreglass, and tiled pools. The Starline Roldeck can be installed during construction or afterwards as a retro-fit option. The Starline Roldeck slats are available in different colours, a solar version, or perfectly transparent.Via our online ordering software it is easy to build your Roldeck and get a quote immediately.
Weiterlesen...
Weiterlesen...
