archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Atmos can be fitted wherever you live and whatever the terrain. The system draws the calories present in the outdoor air and can operate down to outdoor temperatures of -15°C. The evaporator unit is fitted outdoors (wall-mounted or on a base). It draws the calories from the outdoor air by means of a refrigerant fluid evaporating in a battery of copper tubes, then restored the heat to the inside of the home. The hydraulic distribution system is provided by an underfloor heating system composed of crosslinked polyethylene (XLPE) tubes ensuring homogeneous distribution of heat throughout the house. In certain conditions, heat can also be distributed by a system of fan-convectors or low temperature radiators.
Weiterlesen...
Weiterlesen...
