archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Washing machine high spin speed with very robust construction,barrier – wall design separate soiled and clean side) available capacities: 25,35,45 kg divided drum,frequency controlled motor (it has the possibility to set and change the speed according to the sort of linen and it gives a perfect washing result and very smooth washing operation)and freely programmable microprocessor (possibility of changing the water level,temperature, washing and spin times, etc. up to 99 washing cycles available, programmes can be changed very easy via a PC connection or memory card),both sided bearings (long life time of the machine), suspension system and detection of unbalance, damping effects in the machine of the spring-system with shock absorbers and air bags causing minimal vibration (very smooth and very reliable working of the machine),the stainless steel soap dispenser with 4 or 5 removable compartments (dosing boxes) with big capacity for the detergents, the machine has the connections for liquid detergents. Also, the housing of the machine and inner and outer drum and all other parts of the machine that come in contact with water are made of stainless steel material (quality AISI 304), possibility of cooldown system for very sensitive materials (this avoids “thermic shocks” on the linen), easily accesible to maintenance works (all panels of housing can be removed very easily), divided inner drum.
Weiterlesen...
Weiterlesen...
