Anticipate the upcoming chilly days with the new electronic radiator PLANO
archiexpo
12. August 2008
PLANO the new Radialight smart radiator is ready and right on time against the upcoming chilly autumn days.PLANO the new soft heater which combine together a unique design and the comfort of DUAL THERM technology: two different heating systems integrated into a single appliance to give you an intelligent control of power consumption in just 5 cm of thickness. The wide and uniformly heated front radiant surface provides a pleasant and constantly diffused heat which, just like the sun, warms the air and the walls of the room.In really cold weather when more heat is needed, the internal heating core provides all the power required to rapidly reach the temperature set on the thermostat and keep you snug as a bug, with the intelligent use of electricity, thanks to the high precision electronic sensor installed.Still want to save more electricity? The operation of each PLANO radiator can be programmed on a weekly basis thanks to the handy infrared remote control unit ZEFIRO (optional).Programming optimises consumption management.Just one remote control unit can be used to program each single radiator installed in the home, up to an unlimited number of radiators.A specific operating profile can be defined for each day of the week, including a comfort temperature (higher) and an ECO temperature (lower) during each 24-hour period.PLANO is available in 3 different version:- Plano 45, 500 W for rooms up to 8 m²- Plano 65, 800 W for rooms up to 13 m²- Plano 95, 1300 W for rooms up to 20 m²Visit our website www.ermetegiudici.com, to get more information about PLANO and the other products of our heating range.
Weiterlesen...
