archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
Kolant air source heat pump, whole range from 3.5kw to 68kw. Outstand performance High efficiency and energy saving R417A / R407C refrigerant Keep running at -15C Maximum outlet water temperature up to 60C Stepless fan motor speed control Expansion valve keeps the most suitable refrigerant flow in any case. Water flow protection, high/low pressure protection, outlet temp protection etc, keeping the system safety. High Quality and reliability Stainless steel plane heat exchanger with maximum permitted pressure 40 bar 100% stainless water circuit Microprocessor control and error alarm and display Electric protection class IP54 Compact design, easy installation and maintenance World-known brand compressor, pump and main components
Weiterlesen...
Weiterlesen...
