archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
This air handling unit is particularly well suited to the air conditioning of separate zones. It features high static pressure and requires low ceiling heights. The range features a wide array of housings and accessories. Available in horizontal or vertical configurations for indoor installation. All usual functions, such as damper, opacimetric filter, water or electric heating, chilled-water or direct-expansion cooling, ventilation, mixing, distribution plenum, quiet operation, recovery units Installation: ceiling or floor (horizontal units) or wall-mounted (vertical units), Doors on offset hinges, Wide selection of additional equipment. Advantages •Complete range with many easy-to install options (thickness: 400 mm). Low sound level, Double-skin casing insulated with 25 mm thick mineral wool insulation, External sides made of galvanised steel with RAL 9006 and RAL 7024 finish. Components easily accessible via a hinged door with quarter-turn latch, Adapts easily to duct network conditions using plug fan and frequency inverter, Pressure tappings on filtration section, Easy to maintain, Optional control equipment for "plug and play"
Weiterlesen...
Weiterlesen...
