archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
the adjustable base is made of stainless steel in #201 or #304 grade and with 100kg hydraulic lifting gauge, available in coffee-450mm to table-730mm height and table-730mm to bar table-1080mm in 2 heights, 400x400mm square base+column for stability, satin brushed modern look finish, separately packed, direct from the factory, min qty 100pcs! thank you!
Weiterlesen...
Weiterlesen...
