archiexpo
- Registriert
- 12. August 2008
- Beiträge
- 0
3D conception & construction software for architects ABISPLAN 3D frees you from the constraints of the preliminary 2D plan by allowing you to realize your ideas in 3D straight away. From here they can also be corrected, modified… etc. ABISPLAN3D is then able to produce plans, sections and elevations for ABISPLAN2D, where the information for a specific plan (dimensions, areas, texts) can then be added without errors, but with great rapidity. Modeling with ABIS 3D allows you to work in a 'real' (virtual) setting, from the first tracing of a line. 3D means constant control of forms, proportions and relations. Drawing and editing can be executed in all possible perspective views. You are not limited to the Top view, for example, as in many other 3D software programs. Your work is carried in a graphical and non-analytical way.ABIS3D is the ideal tool for all construction types (timber, steel…etc) and does much more than create a standardized architecture. Intelligent switching:At any desired moment, it is possible to make an easy switch from 3D to 2D or vice versa.
Weiterlesen...
Weiterlesen...
