A good figure with bim
archiexpo
12. August 2008
The Corpus Museum in Oegstgeest, The Netherlands The journey into ones self or your body– is a dream that many people have and could previously only be experienced in the cinema. But that's all changed now with the opening of the Corpus Museum, in Oegstgeest, the Netherlands. Opened this Spring, this special museum actively invites visitors to take a journey through the human body from head to toe and find out “in situ” how we work. This is made possible thanks to a 35-meter high figure of wood and steel that flanks the narrow side of the glass museum structure. Designed by PBV Architecten, construction of the building was a particular challenge, which the commissioned designers from 3D Blueprint Architects & Engineers overcame with flying colors. Thanks to Building Information Modeling and Allplan from Nemetschek, the Amsterdam-based architects were able to complete the building on time and even remained below the planned budget. Building Information Modeling (BIM) relates to the consistent use of a virtual building model across all phases and disciplines of design, construction and management. Thus, BIM makes it possible to design construction projects that are inexpensive, free of errors and on time. This is exactly what Joep Esser and Wubbo Hazewinkel had in mind when they founded their company six years ago, and they have therefore used BIM and Allplan from the very start: “3D Blueprint's goal is to build better and at lower cost through effective cooperation,” explains Joep Esser, managing director of the company. The architects and engineers have developed their own working method for this, known as the “Regiplan method”, which is based on BIM. In Allplan's virtual building model, all project-relevant information is entered centrally and The designers draw up the project requirements with the building client in advance in a “building program”, which formulates a clearly defined and feasible goal. An initial (basic) three-dimensional building model is created for this in Allplan, which allows reliable statements to be made on quantities and costs on the basis of the assigned material properties. Economic factors can therefore be taken into consideration from the start and tracked over the entire project period: “For decision-making, the coupling of planning and costs enables us to identify the lower-cost option and therefore counteract incorrect developments at an early stage,” explains Joep Esser. “As a result, we are able to reduce the costs of a building project by 10 – 15 percent, for example, or to deliver a higher-quality building at the same construction costs.”
Weiterlesen...
