500-T: standard Aquatic Therapy Pool
archiexpo
12. August 2008
The 500-T pool is identical to the 500-OT model except it is manufactured in four pieces of superior fiberglass pool construction instead of one. This allows the ability to move the pool into existing and/or tight spaces. This aquatic therapy pool is shipped in pieces and assembled on-site. The SwimEx 500-T is a multi-depth pool, adjustable to depths of 38 inches and 50 inches (96.5cm and 127cm). The pool features eight distinct workout stations, including, plyometric pads, open and closed kinetic exercise benches and steps, and an angled running platform. The treadmill simulator (40 degree angled pad) allows the athlete to begin running in a limited weight-bearing environment and the adjustable floor allows the therapist to gradually increase weight-bearing activities to allow a smooth transition to land.STANDARD FEATURES One-piece fiberglass pool construction Built-in molded seats - two on each side Filtration system (5.5-kw electric heater, 3/4-hp pump, 75-square foot (22.86 square meter) cartridge filter) Equalization Skimmer Recessed steps with stainless steel handrails Stainless steel handrails Air operated swimmer controls (stop/start & fast/slow) Remote control pool control Rear emergency shut-off bar Non-skid floor surface Electronic controller - converts 208-240v single phase to 3 phase Stainless steel electropolished front and rear grates 5-hp electric motor with paddlewheel drive system Thermal blanket (cover) Start-up chemicals and water test kit Annual maintenance kit Swimometer™ - water speed display and programmable timer Four underwater observation windows Two stainless steel front handrails Royal blue ceramic waterline tiles Treadmill simulator (40-degree angled pad) for stationary running Eight colored workout stations built-in around perimeter of pool Floor inserts (38-inch (97cm) depth) with removable pole Basic Water Accessories Package On-site Personal Educational In-serviceThe 500-T aquatic therapy pool circulates up to 30,000 gallons of laminar water flow per minute (113,562 lpm) - creating a wall of water that generates over 40 water speeds. The patented SwimEx water current creates an ideal environment for strength training and functional activities during all phases of the rehabilitation program in this therapy pool. Increased versatility is available with the optional SPT Underwater Treadmill or other water exercise equipment.POOL SPECS Pool Size: 7'8” 17'6” x 5' (2.34m x 5.33m x 1.52m) Pit Size: 12' x 20' x 5'5” (3.66m x 6.1m x 1.65m) Pool Weight with equipment: 3,200 lbs (1,451kg) Pool Volume: 2600 gal (9841 l) Pool Filled Weight: 25,000 lbs (1,133kg) Load Bearing: 425lbs sq.ft. (2074.31 kg/m2)
Weiterlesen...
